Turn the key and nothing 91 gta
Old May 8, 2009 | 06:35 PM
stock's Avatar
Car: 91 gta and chevy powered toyota
Engine: 5.7 in both of them
Transmission: 700r4 raptor
i bought a gta from someone that could not get it to run! it has been sitting for 4 years
they broke the coulum and the ignition out..the key was broke in half..
i changed the coulum and had a new key made to fit the vats set up ..
i learned the new key ,and tried to start the car and i have nothing !!
i jumped the starter and it cranks ,but when you turn the key i have nothing,,changed the neutral safty switch,and the relay at the kick panel.and even tried a working ecm ,you hear the fuel pump kick on ...
anyone have any ideas? i tried everything i could before i posted this thread,,googled the crap out of it!! here is the car
Old May 8, 2009 | 06:59 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Turn the key and nothing 91 gta
try this - it may be a fusible link and i think i am attaching the correct page in pdf form. look at fus link and it will show the column and row where they are located.
if anyone did work and did not disconnect the battery you can get a short and fuse one - melt it in half.
also check to see if the vats reader in the column by the key is working and if there is even a vats module by the fuse box. if there is then you should at least get a lights going on and the check engine light will go on - i think that is it.
do a search of VATS and fusible link for info from people a lot smarter than i am, but dont tell anyone i admitted to that.
good luck
File Type: pdf
Old May 8, 2009 | 07:01 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
you can try grounding out the starter relay, that will override the cranking circuit of the vats system. If that works then you know there is still a vats issue, either the key, ignition lock or module itself. Hope this helps.
Old May 8, 2009 | 07:44 PM
stock's Avatar
Thanks i will try in the morning..
And thanks for the quick response both of you.....
all the lights come on like they should ..but when you turn the key to start..
it no go
Old May 12, 2009 | 04:58 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Any progress?
Btw, before you throw away more money on random parts, try this troubleshooting article to find out WHAT is wrong with the starter circuit:
http://www.austinthirdgen.org/index.php?pid=38
Since you already verified that the starter itself can crank, you should have no trouble finding the faulty component with just a test light.
Hope this helps.
Lou
Old May 13, 2009 | 10:23 PM
3rdGenDrifter's Avatar
From: I'm from hawaii, but I've been going to school in Grand Forks, ND for four years now
Car: 1989 Camaro, 1991 Firebird
Engine: 305 in the chevy, 350 in the bird
I think I'm having the same problem with 89 Camaro. Everything works (lights, music, blinkers, security light) except just randomly, usually once I'm already somewhere in town, when I turn the key... nothing happens. Usually if I just wait a few minutes (5-20) it will decide to crank right over and light up, but sometimes it takes longer. Totally inconsistent though. Driving me nuts! I need to be able to rely on my car for work, etc.
Old May 14, 2009 | 06:26 PM
My 91 Z does the same thing, mine has a problem with the VATS decoder in the ignition lock cylinder. The wires get brittle and break off or just develope bad connections. When your car will not start, is the security light constantly lit as long as the ignition is on?
Old May 15, 2009 | 04:59 PM
stock's Avatar
Its all good now...finally got some time off of work to d=ck around with it some more..
the neutral safety switch was not in the correct spot,,,kicked right over...
best 1,000 bucks i ever spent ... 91 green gta with 80,000 orig miles..
Thanks for all your help!!!
Old May 15, 2009 | 05:35 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That was a score bro. Post some pictures? Whats all modified on it?
Old May 15, 2009 | 06:07 PM
stock's Avatar
unmolested car!! just an ram air hood and a flowmaster,and k&n filter.
5.7 car..i guess it is one of 508 made in the color green that year...
my avatar is the the car bought!
This is the other 91 , 5.7 headers w/test pipe to flowmaster custom prom slp runners slp cold air intake k&n,
4th gen 17 inch speedline wheels,3.42 rear from a 4th gen 4th gen leather seats...I will take some more pics this week end of them both...
Thanks guys
Old May 17, 2009 | 06:47 PM
Yes it is. I really need to get some time off so I can dig into this problem
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
Bryan F
Aug 18, 2015 02:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
Kaweh
Aug 9, 2015 02:54 PM
