Engine will not crank... Please help..
Old May 9, 2009 | 07:45 PM
relic87239's Avatar
Car: 1988 Chevrolet Camaro
Engine: In the market
Axle/Gears: 2.77
Car was running fine, and one day i turn the key and the engine cranks one time then nothing. This happens every time. I had the battery and the alternator tested, they are fine. It has a new starter, coil, module, wires, and plugs.
I am not sure where to go from here. Where can i begin troubleshooting?
Old May 10, 2009 | 12:44 AM
GadeXTrigger's Avatar
Car: 91 Camaro
Engine: 5.7Fl V8 350 tpi
Transmission: 700R4 Automatic
Re: Engine will not crank... Please help..
new dist or just new pickup coil
Old May 10, 2009 | 02:41 AM
relic87239's Avatar
Axle/Gears: 2.77
well motor is not cranking at all so i wasnt sure whether or not the dist coil and all had any affect. figured if the coil or module were bad that the engine would crank but not ever start. so your saying i should check the pickup and the dizzy? the coil and module do have miles on them so they could potentially be bad.
Old May 10, 2009 | 11:14 AM
relic87239's Avatar
Axle/Gears: 2.77
any ideas?
Old May 10, 2009 | 05:55 PM
Oldsmobileman's Avatar
Car: 1991 GTA
Transmission: Stock
Axle/Gears: Stock
Does your car make any noise at all when you turn the key or do you get no sound at all? I have been told sometimes the chip in the key goes bad and the ignition will not let the car do anything at startup. Don't know if this helps.
Old May 10, 2009 | 09:53 PM
relic87239's Avatar
Axle/Gears: 2.77
thanks for your advice and thanks tgo. With a little research, helpful threads, a lot of patience, and a multimeter I was able to trace the problem to the starter enable relay. I pulled the cap off and saw one of the prongs was scortched. This immediately said FRIED.. with a little testing indeed that was it. Definetely learned a lot on this one.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
