valve overlap
Old May 12, 2009 | 09:20 AM
Floorman279's Avatar
valve overlap
is there a specific degree of valve overlap that makes a cam fail emissions? like is 70 degrees max for example?
Old May 12, 2009 | 10:12 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: valve overlap
You have the right idea, but you're looking at the wrong specs. The one thing that every emissions-legal cam has in common is NO overlap at .050". So forget overlap at advertised duration.
Old May 13, 2009 | 10:08 AM
Re: valve overlap
so as long as there is no overlap at .050 than it is emissions legal?
Old May 13, 2009 | 12:02 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: valve overlap
close. If there is no overlap at .050", it CAN pass the sniffer test, but may idle noticeably and/or not have an E.O. number.
Old May 14, 2009 | 05:56 PM
Re: valve overlap
ok so high lift cams (.520 or so) will give you a pretty rough idle. you say that there is a certain sound that it needs to be below to pass?
Old May 15, 2009 | 11:46 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: valve overlap
Lift has nothing to do with emissions. There are plenty of reasons to think so, but if you get a modern hydraulic roller, and use high-ratio rockers, you can get past .560" lift and still be clean. They can't fail your car for sound, if you meet the loudness laws as to how many decibels, and your parts all have E.O. numbers and you pass the visual and "sniffer" tests. Now, consider why you want lift: It's to let good heads be fully taken advantage of. On most stock GM heads, there's no point trying to get past about .500", but with something like AFRs, then you should be trying to approach .600"
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
