Clicking sound and Oil Leak
Old May 14, 2009 | 04:00 PM
10secondhopeful's Avatar
Car: '84 Z28
Does it on start up in the morning. It's not just a real subtle sound that you have to strain to hear, its pretty obvious. Just piston slap or something serious? quits after it warms up to normal temp, i just want to make sure.
Also have a pretty bad oil leak coming from somewhere near the back of my motor, any ideas on what it is? my dipstick is really lose could that be the problem?
thanks
Old May 14, 2009 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably lifter tick.
Oil leaks from the back of the engine could be intake manifold, valve cover (most likely), or oil pressure sending unit.
Old May 14, 2009 | 06:06 PM
firebirdman's Avatar
Car: 89 Firebird Formula
Engine: 305 tbi
Axle/Gears: 10 bolt 3.42
Re: Clicking sound and Oil Leak
could be your main seal if its leaking from the back.
Old May 14, 2009 | 06:20 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
A good way to go about checking knocks or ticks is to listen for the timing of it, a camshaft related tick should occur at half the engine crank speed (rpm), a crank sound would be on time with the rpm's.
Old May 15, 2009 | 10:08 AM
Car: '84 Z28
Thanks for the help guys i'll dig into it this friday when i install headers
Old May 15, 2009 | 10:11 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
exactly what mine was.
xxx3man`
Sep 23, 2015 10:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
drathaar907
Aug 6, 2015 04:20 PM
