638 Roller Block, Scrap or not?
Old May 14, 2009 | 10:22 PM
SLOWMARO355's Avatar
A customer brought his truck in a few days ago. I pulled the motor and pulled the pan.
He said it ran hot, ran low on oil and locked up. Lmao. What do people do to these cars.
Should I even tear this down, or just keep accesories and junk the block?
Old May 14, 2009 | 10:27 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: 638 Roller Block, Scrap or not?
milkshake means antifreeze in the oil - there is a crack someplace in the head.
Old May 14, 2009 | 10:53 PM
Im aware of thar sir. What if the blocks warped?
Old May 14, 2009 | 11:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The crack could be in the block. Check the sides of the lifter valley.
Heads are more likely to warp than blocks. But, about the only way to know is to pull it apart, clean it up, and check it over.
Old May 14, 2009 | 11:29 PM
Ill pass on that, shops too busy. Ima sell him my 305 and put my gas guzzln 355 back in. I have a 2 speed powerglide. Will I get better mileage with the 350?
Old May 15, 2009 | 11:41 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
638 blocks do tend to crack in the lifter valley. But it can be repaired. I've done so successfully, more than once.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
anesthes
Sep 18, 2015 12:34 PM
RyanJB
Sep 14, 2015 03:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
