Fuel pressure problems, please help
Old May 15, 2009 | 10:41 AM
JN56's Avatar
Car: 1987 Formula 350
Engine: 5.7 350 TPI
Transmission: 700R4 w/ shift kit
Axle/Gears: 9 Bolt BW 3.27
Hey guys,
Since last week my car has been starting hard. Usually have to crank it 3 or so times before it turns over but once it does it runs like a top.
Now according to All Data, the fuel pressure for the pump with only the ignition on is between 40.5 - 47 psi and the pressure at idle should be 30.5-44 psi
So i hooked up the fuel pressure gauge today and there is no pressure at idle at all. There is nothing until I start cranking it and then it works its way up enough to start and once its running it idles right at 44psi
So basically i have no idea what to do next. i talked to my mechanic about it and he is going to look at All Data again to see if there is any fuel pump relays or something before we go and change the pump. Honestly i dont think the pump needs to be changed since once the car starts the pump works 100%.
Does anyone have any ideas about this or anyone have a problem like this before? its a 87 formula 350 TPI
Thanks guys, this is bothering me.
Old May 15, 2009 | 04:38 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Fuel pressure problems, please help
I assume that you mean that there is no pressure when the key is first turned on, but before cranking it. Sounds like your fuel pump relay is not doing its job and the engine is only starting after oil pressure starts building.
Old May 15, 2009 | 10:22 PM
JN56's Avatar
Engine: 5.7 350 TPI
yes, there is no pressure when the key is in the in the "on" posistion but not running. once it starts up it runs fine...
Old May 16, 2009 | 07:01 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Fuel pump relay is not priming the pump. Car is starting only after oil pressure builds up and turns on the fuel pump.
Old May 16, 2009 | 05:00 PM
JN56's Avatar
Engine: 5.7 350 TPI
I can hear the fuel pump prime when i turn the key on but its not getting any pressure...
Old May 16, 2009 | 06:51 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Sounds like the symptoms of a pump going out. There is a fuel pump "priming" connector under the hood, near the under hood light on the passenger's side. It's just kinda sticking out there. You can apply 12V from the battery (using a jumper wire) to make the pump run even with the key off. If it still takes seconds of running to make it build pressure, then the pump or pressure regulator is messing up, keeping it from building pressure. My last fuel pump developed an internal leak that kept it from building/holding pressure.
The pressure gauge needle should pretty much snap to position and stay there for minutes after turning the pump off. If it leaks down quickly, then it's either the injectors or pressure regulator not holding.
Old May 16, 2009 | 09:56 PM
Rick1805's Avatar
Car: 1992 Camaro
Engine: small block chevy 355/300hp
Would also check your fuel filter if its bad and not letting alot of fuel though it would cause a similar problem. If you have checked that or its fine (and thats the cheap fix) your looking at replaceing the pump because just like afremont said good possibility your pumps leaking back on its self and not holding the pressure you need to get past the fuel regulator
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
