Intake Bolts Wont Come Out
Old May 16, 2009 | 05:40 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
well im taking the intake off of my 305. im 3 bolts away from success. 2 on one side of where the carb sits. the other on the opposite side. (my friend managed to get one out).
i didnt have any WD-40, but i poured 3 in 1 around the bolts.
i'm still having trouble getting them off. does anyone have any tricks or ideas?
Old May 16, 2009 | 06:09 PM
Convoy25's Avatar
Re: Intake Bolts Wont Come Out
anyone?
Old May 16, 2009 | 06:54 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
WD40 is pretty useless. Deep Creep, Kroil, or or PB Blaster are all much better choices. Use only 6 point sockets. A quick whack with a hammer can help free them.
Old May 16, 2009 | 06:58 PM
Convoy25's Avatar
i also heard about that loctite freeze and release and another freezer.
hit the bolt with a hammer dead on?
it somewhat tricky to get to, the bolts are angled and the platform where the carb sits keeps me from getting some extensions in
Old May 17, 2009 | 01:24 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you can't get a socket on the bolts, have you tried a box end wrench?
Old May 17, 2009 | 01:26 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
You've tried a box end wrench, I hope.
Old May 17, 2009 | 02:12 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i dont know much about carb inakes but the principle is the same, i recommend new bolts after this and a torque wrench to reinstall.. , if i were doing this, id take wb40, let soak in a puddle around the bolts, then 5 - 23 hours and 59 minutes and 56 seconds later.. id take a propane torch and heat it up, then attempt to take it off,. on my intake, vise grips was used because of a stripped torx head
Old May 17, 2009 | 08:18 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
put some ATF on them. trust me i have done this in the past and it works just as good if not better than penetrating oils.
Old May 17, 2009 | 12:34 PM
Convoy25's Avatar
yes i've tried a box end wrench. but it's difficult to get on because of the formation of the intake. theres a side thats close to the wrench. and when i did get a wrench on one of them, it wouldn't budge at all.
what's ATF? im gonna run to autozone after work today
Old May 17, 2009 | 12:36 PM
Convoy25's Avatar
oh and i don't really car about damaging this intake. i have a new one i'm gonna put on. i'm just worried about the top of the last 2 bolts breaking off
Old May 17, 2009 | 01:20 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Do you have the valve covers off?
IIRC, the threaded ends of the bolts are visible when the covers are off. You can attack the threads from this end with penetrating oil, etc. Might be more effective than waiting for the penetrant to slip past the bolt heads.
Old May 17, 2009 | 02:32 PM
Convoy25's Avatar
drivers side valve cover is off. you can see the bolts through there? hmm i'll take a look
Terrell351
Jun 13, 2021 01:13 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
