tpi rough idle flooding?
Old May 17, 2009 | 08:33 PM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
I have a 87 iroc tpi 350 that idles very rough like it has a big cam in it and runs very rich. Once i rev it above about 2000 rpms it smooths up but returns to symptoms when at idle. I have a code 34 for the maf. This a very expensive part but I dont think this is my only problem. I read somewhere that when you unplug the maf it will run better if the maf is faulty. I can unplug the maf and there is no change at all. Maybe a bad ecm? bad prom? Im so aggravated im thinkin of swapping to a carb. I have replaced IAC, dist module, TPS, coil, and checked all grounds and connections. I also tested the injectors and they all read 16.8 ohms. Any help would be greatly appreciated
Old May 17, 2009 | 10:23 PM
LuckyGen3's Avatar
Engine: 5.0L TPI F Code
Transmission: 5-spd Manual
Re: tpi rough idle flooding?
Try this: Spray starting fluid around all of the gaskets for the intake. If the idle increases you have a bad gasket. I tried this in my '88 Iroc Z with the 5.0L TPI and found that I had a vacuum leak where the throttle mates to the intake plenum. I now have a '88 Trans Am with the same motor and same problem. I did some research and it turns out that the intake is under the most pressure below 2000rpm and when you floor it the intake pressure drops dramatically. On my Z, I only found it with starting fluid. On my T/A I could actually hear it sucking air.
Old May 17, 2009 | 10:42 PM
Nub383's Avatar
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
Are you sure its running rich for sure? I agree that you probably have a vacuum leak.
Old May 18, 2009 | 07:02 AM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
i had same problem. give you any trouble when starting?
for me it was the fuel regulator
Old May 18, 2009 | 07:58 AM
Car: 87 iroc
For sure its flooding, black circles on the ground under the tailpipes, fumes are very strong at the rear of car. And it starts first bump of the key. I pulled the vacuum line of the regulator and theres no gas in it. Also adjusted the tps to .540 . Rarely but sometimes I can start it up and not touch the pedal and it will idle perfect until I rev it one time then the symptoms return.
Old May 18, 2009 | 06:50 PM
Car: 87 iroc
today I replaced the maf and the ecm w the prom, and still starts right up and floods for about 5 seconds then stalls out. If keep reving it it will keep running. I bought a whole other 88 irocz w all the parts to fix mine so at least i wont go broke trying to figure it out, Im thinkin of changin the cold start injector next, does anyone think that could be the problem?
Old May 19, 2009 | 04:20 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
do you lose fuel pressure when the engine is off? ...if the 9th or any injector was leaking.
did you test or replace the 2 relays for the MAF sensor?
Old May 19, 2009 | 04:41 PM
Car: 87 iroc
problem solved! some idiot adjusted the throttle up using the idle screw that youre not suppose to mess with. i backed it off and readjusted the tps and wham o its fixed
Wade787b
Sep 29, 2015 01:15 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
