Pesky oil leak I can't trace down!
Old May 21, 2009 | 03:11 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
I have a small oil leak coming from the rear of the motor somewhere. I replaced the intake gaskets thinking it might have been the rear RTV on the china wall. Fixed that, it's not leaking from there. It's not the rear main seal either, I checked that. It seems like it doesn't leak until after my car is shut off from running, then I will have a couple small puddles the size of a 50 cent piece (sometimes more, sometimes less) under the oil pan towards the trans. Any ideas? I was thinking maybe a valve cover but I really am not sure.
It's just really more annoying than anything else.
Old May 21, 2009 | 08:38 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: Pesky oil leak I can't trace down!
Check the oil pressure sensor. Top (driver side) rear of the engine. It is known for leaking.
https://www.thirdgen.org/forums/elec...ure-gauge.html
Old May 21, 2009 | 09:17 PM
CHAMARO's Avatar
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
check OPS and rear of valve covers. always diag leaks from top to bottom, look for trace and follow to its source. if its too messy or you cant see it wash the motor (or just the rear in this case), pour in some oil UV dye, and watch for the leak with a UV light. if its not visible from the top the uv light should make the path obvious from below.
Old May 21, 2009 | 09:27 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I used my VCR and serveillance camera with night vision to locate an a very slow oil leak.
Old May 22, 2009 | 01:19 PM
Car: 91 Firebird
Engine: Turbo 355
Thanks for the replies. I tightend up the OPSU with the special socket, but I didn't put new pipe dope on the threads... I may take it back off and try again with some pipe dope on the threads. It didn't seem to be the valve covers or the dist gasket.
Old May 22, 2009 | 06:46 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
They usually leak on the crimp where the two halves meet. Tightening it won't help.
Old May 22, 2009 | 09:48 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Unless the pipe dope is conductive it will interfer with a one wire sensor making metal to metal to complete the ground circuit.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
