Car tuned-now idles too low and stalls out?
Old May 21, 2009 | 07:24 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I had my 84 T/A tuned on a Chassis dyno after having my new 350 dropped in and it seems to be idling too low now...but only when really warmed up.
When I start the car the engine is idling around 1200 or so, once it warms up that drops down to 900ish....(closed loop I believe it the term I'm looking for). Anyway, I drop it into gear and it hovers around 650 or so...but then it starts stumbling...eventually dropping in idle until it stalls out. Now, once the car is warm (180+ with my 160* thermostat), even in park the idle will start to stumble a bit and sometimes eventually drop so low that it will stall out.
When the weather was cooler, the idle stayed semi-high, even once warmed up, around 800ish when in gear and I didn't have this problem. Any ideas?
Just a side note, I really love how the car sounds idling a 650, has a really mean rumble to it.
Old May 21, 2009 | 07:39 PM
theMAGICALheat's Avatar
Car: 96 Souped up Firebird, 89 KITT
Re: Car tuned-now idles too low and stalls out?
sounds exactly what we had... we replaced the throttle positioning sensor and now ours is fine.
Old May 21, 2009 | 07:56 PM
Ozz1967's Avatar
Car: 1984 Trans Am
does a carbed car even have a throttle positioning sensor? This wouldn't be equivilent to my idle stop solonoid would it?
Old May 21, 2009 | 08:23 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
For a carb car, dont you hsve an idle screw? I would reset the idle speed and re-adjust the timing.
Old May 21, 2009 | 09:48 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I'll check the idle screw, but I was under the impression with a Electronically controlled carb you didn't really want to mess with the idle screw...
As for timing, i'm at 12 advanced initial (distributor unplugged), 36 actual, I believe is what the dyno guy said.
Old May 21, 2009 | 09:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
On my '87 EFI OBDI car, I do set the idle RPM and can set the base timing while the EST wire is disconnected. So, I assume that there should be no issue with you doing the same as long as you follow the proper instructions.
Old May 23, 2009 | 07:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I'm just curious about how this is supposed to run because the idle, for the most part stays where it's supposed to but...for example.
Today I came home from work, (13 miles one way), the car was well warmed up but when I put it into park, it jumped to high idle (1300ish). put it in drive again, dropped to 650-700, back to park, normal idle (1000ish). I just wish it would stay where it's supposed to. it's been crazy ever since I put this new 350 in the car.
Old May 24, 2009 | 09:22 AM
DaveBerlinetta's Avatar
Car: 1985 Berlinetta
Engine: 5.0 LG4
Axle/Gears: 3.08 Peg Leg
On the CC carb, it does have a throttle position sensor. It's just buried inside the carb. It's located on the driver side front; you can see the three pin connector coming out the front of the carb.
The idle stop solenoid is used to increase idle when the A/C is turned on.
Attached Thumbnails Car tuned-now idles too low and stalls out?-01-car.jpg   Car tuned-now idles too low and stalls out?-02-car.jpg   Car tuned-now idles too low and stalls out?-sensor-out.jpg
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
