rapid clickng from starter.
Old May 21, 2009 | 09:54 PM
88tpi350's Avatar
Car: 88 formula
Engine: 350 goin carb
well, my starter worked fine when i park my car in jan, went to try to fire it up today and it has a rapid clicking, almost like when the battery id dead but WAYYYYY louder. Any ideas?
also anyone know how large of a fuse i should put in between the battery and the starter, i have a 100 amp now and it pops when i hit the button
thanks
Old May 21, 2009 | 10:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: rapid clickng from starter.
It sounds like either the battery voltage is too low to keep the silonoid (sp) engaged or the silonoid is bad.
Old May 21, 2009 | 10:10 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
grab the wires and wiggle it to make sure its tight. If its not tighten it. Make sure its tight w/o corrosion. Then check the battery level and if its good then it should start. No need for a fuse b/c its on a relay already.
Old May 22, 2009 | 07:50 AM
88tpi350's Avatar
Car: 88 formula
batery is good, wires are good. even tried a jump box. o well im going with a screwd up starter. i guess clicking isnt the right way to describe it more like a loud banging.
Old May 23, 2009 | 10:57 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Put the car up on ramps, and give a few good whacks with a ball pean hammer, then try to start it. If it starts, then your armature is probably dirty and caused the starter gear to get jammed in the flywheel.
Old May 23, 2009 | 12:03 PM
88tpi350's Avatar
Car: 88 formula
yeah pulled it up on ramps and the sterter housing is in pieces, no clue what happened there, oh well thanks for the advice
Old May 24, 2009 | 09:28 AM
Car: 1989 Camaro
69GTOby
Apr 18, 2016 02:34 PM
Gunner242
Dec 25, 2015 04:49 PM
meeklay812
Oct 1, 2015 03:46 PM
Cleotiz
Sep 16, 2015 08:02 AM
383cam
Sep 9, 2015 06:01 AM
