Convertering from points
Old May 21, 2009 | 10:33 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Not sure if this is the right spot for this but here it goes. I still have points ignition on my 1970 350 block and i want to convert to HEI what distributor do i need? Should i go with computer controlled if i want to add a MSD digital ignition box? or should i just buy the box and keep the points?
Thanks Chas
Old May 21, 2009 | 11:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Convertering from points
You can simply drop in a large cap HEI distributor. Supply a good switched hot source wire and it's ready to go.
With all the superior electronic ignitions available including the factory ones like the large cap HEI, there's no reason to run points.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
