Identify that wire
Old May 22, 2009 | 03:32 AM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Identify that wire
Anybody know what this is? Its down by the starter on my 350 TBI. I've looked around and dont really see anywhere for it to connect.
Old May 22, 2009 | 04:21 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Identify that wire
that pigtail goes to the fan switch located in the passenger side head, the knock sensor uses the same style connector but from the angle of this pic thatd be impossible not to see plus youll be throwing codes like crazy
Look from the same angle up on the head youll see the sensor, itll be on the head between two of the spark plugs on the rear half of the head
Good Luck
Old May 22, 2009 | 09:30 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
hrm seen absolutely nothing between the spark plugs. I will look again tomorrow and try to get a pic.
Old May 23, 2009 | 05:34 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
In between #4 & #8 below spark plugs and just above the starter.
There are 2 connectors on the passenger side with that type of connector; Fan temp switch, and Knock Sensor. KS is center of block just above the oil pan rail.
Old Jun 2, 2009 | 12:19 AM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
finally got it back up on jack stands and took a long again. I still cant find anything else on that side. here's a pic showing the one connector I did find:
thats the knock sensor right?
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
