Drivers side window won't go up / down...
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Is there a switch or a motor I have to replace in the actual door itself? If so, how easy is it to do and how much is the part? What is the part called I'm looking for as well?
Thanks,
Thanks,
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: Drivers side window won't go up / down...
I'm assuming you have power windows. If that's the case and the window went up and down rather slowly before it just stopped working, then you need a replacement power window lift motor. Autozone can hook you up for around 45-55 bucks. While you're there, you might want to buy a manual for your car. It'll make it a lot easier to make this repair, and there nice to have. The job shouldn't be too hard.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
