EGR Valve block plate?
Car: 1986 IROC-Z
Engine: 350 ci
My 86 IROC TPI has a block plate over where the EGR valve goes...is this detrimental to the car or no big deal. Im having a nasty bug and I wonder if its related. After running for about 30 to 40 minutes once I come to a stop and let it idle it while often try to die like its outta fuel, and you can stop it, and once it dies it won't restart until its sit and cooled down, then it fires back up, so it seems something is getting hot.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: EGR Valve block plate?
The blockoff plate is fine.
Sounds more like you have issues with either your injectors, coil, or ignition module shorting.
Zachattack0925
Aug 12, 2015 09:52 PM
