tpi 350 heads sugestions (see specs)
ok guys i can decide on what set of heads i should get or if i should just tweak the stock heads and have the work done but the specs are
tpi intake upgraded runners and base etlebrock
heads are stock
cam is Cam specifications: Duration & lift @ .050 & Lobe separation angle (LSA)
Lobe center angle is 113 , durations @.50lift is 230 intake ,236 exhaust valve timing @0.006 lift
Open intake 31 btdc close abdc 96
Exhaust open 81 bbdc 27 atdc
Comp cam part number 12-467-8(10) grind number 280xfi hr13
Using 1.6:1 rockers hydraulic roller lifter
26 pd injectors
adjustable regulator
steel crank ,
high volume oil pump
now any sugestions on the heads for this or and would i have clearance issues with flattop pistons ?
is my cam to aggressive for tpi ?
heads are stock
26 pd injectors
steel crank ,
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: tpi 350 heads sugestions (see specs)
far too much cam for TPI. And you wait on choosing a cam until after you have the best heads you can afford.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
again, you don't pick the cam until after you get the best heads you can afford. Hopefully AFR's 180cc heads. Some heads have poor exhaust ports and need extra exhaust duration, others have ports that stall beyond a certain lift. Get heads first, then you can worry about a cam.
NinjaNife
Aug 23, 2015 11:49 AM
Sanjay
Aug 12, 2015 03:41 PM
