Filling the tank
Old Jun 3, 2009 | 07:35 PM
nitemare70's Avatar
Car: 83 Z28
Engine: Comp Controled 350 w/ carb
Transmission: 5 Speed
Filling the tank
I may be in the wrong thread but here it goes. I bought an 83 Z cheap!!! Previous owner installed new tank(brand new!!). I am having trouble filling up the tank. Gas runs in for a few seconds then cuts off. Filler neck is full but gauge shows 1/4 tank. It is like it is not vented and needs to burp. Does anyone have any suggestions?? I have tried pouring fuel in with funnel and can very slow, same results.
Old Jun 3, 2009 | 08:37 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
Re: Filling the tank
I would replace the sending unit and then try with a known working gauge (not the one currently in) and if it's still reading 1/4, you know it's got to do with the tank.
If it reads differently, you know your sender or the gauge or both were bad.
Hope this helps.
Old Jun 4, 2009 | 02:46 AM
nitemare70's Avatar
Car: 83 Z28
I have not found a known working gauge. I have put in a new dash cluster and get the same reading from both gauge sets though.
Old Jun 4, 2009 | 03:09 PM
Tpx's Avatar
Tpx
what about the sender? Did you replace that
Old Jun 4, 2009 | 03:41 PM
Stephen's Avatar
Car: 87 GTA
Use a long metal rod (like 1/8") to stick in & see if the tank is actually full or not first.
I can't imagine dropping the tank to get the sending unit out, with a full 14 gallons of gas, at 8lbs per gallon.....Not exactly light!
If its pull, you can use a hose to siphon the tank into a jug first, before dropping the tank......Or just do the gas pump access door mod & be done much faster! You'll get lovers & haters on that mod.......The haters have never done it, the lovers can't imagine having another 3rd gen without it.
Old Jun 4, 2009 | 05:45 PM
nitemare70's Avatar
Car: 83 Z28
I have read a lot of posts both for and against "door" mods. If I ever did it (not saying I will) I would not tell a soul!!! Too many strong opinions on such matters.
Old Jun 4, 2009 | 08:57 PM
Tpx's Avatar
Tpx
lol I've never heard of the "gas door mod" i'll have to search for that lol
Old Jun 4, 2009 | 09:33 PM
Stephen's Avatar
Car: 87 GTA
Fuel pump access.......
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
kx3g
Sep 28, 2015 08:14 AM
lanceflame44
Sep 25, 2015 12:28 PM
