502 spark plug
Old Jun 4, 2009 | 07:04 PM
z502's Avatar
502 spark plug
bbc 502 ,580 lift,demon 850 cfm what spark plug do i need ? tanks
Old Jun 4, 2009 | 09:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 502 spark plug
Depends if the heads use a tapered seat or gasket plug.
What exactly do you want to know? The only important thing to know about spark plugs is the heat range. You need to run the coldest plug possible that doesn't foul up. The required heat range depends on a lot of factors such as timing, jetting, compression ratio.
With a tapered seat and using AC Delco plugs, put in R43TS plugs.
Generally, use the exact same plugs you would use in a SBC. BBC normally can use at least 1 heat range colder than SBC.
Old Jun 5, 2009 | 06:36 AM
z502's Avatar
Re: 502 spark plug
compression ratio stock heads stock ,for now i using ac delco r44ts plugs
tanks
Old Jun 5, 2009 | 01:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 502 spark plug
If the R43TS foul up, up the R44TS back in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
