92 camaro RS starting issues!
When attempting to start, I can hear the starter and it sounds normal. Engine will turn eventually and fire but struggles to stay on, then stops; will sometimes start if I give it gas after it fires and then seems to run normally. There is a strong gas odor under hood and there is gas residue in air intake duct. The starter, plug wires and plugs are all new. Please, any input?
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Re: 92 camaro RS starting issues!
Can you post a video with sound? Lot's of possibilities, need more info.
