Knock sensor coolant leak
Old Jun 4, 2009 | 11:44 PM
eldy's Avatar
Car: 89 formula TPI
Engine: 5.0 l
Transmission: 5 spd
Axle/Gears: 3:45
From the new guy with dumb question. " what keeps the coolant from running out of the hole in the block casting when the knock sensor is removed from a 305 Vin F???? I removed my knock sensor to replace it and decided to clean out the bottom of the tapped hole in the block. Opps...I puntured something that looks like brass covering in the bottom of the hole and coolant poured out on my head. OK I guess I did something bad but how do I fix this problem? I can't find any references in the manual or on line to "freeze plugs or expansion plugs, etc in that location. Thanks for any help.. My wife already thinks I am stupid for this "snafu"...
Old Jun 5, 2009 | 12:14 AM
Guest
Guest
Posts: n/a
Re: Knock sensor coolant leak
The knock sensor is what keeps the coolant from leaking out. Put the new one in (that should have sealant on the threads) and forget about that thin layer of rust and debris you broke through.
Old Jun 5, 2009 | 01:08 AM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
In your manual it should mention to drain your coolant before replacing sensor its ok though I had no idea either until I put together my first motor lol
Old Jun 5, 2009 | 01:46 AM
IROCKMYIROCK's Avatar
lol that's too funny i hope you're hare washed out ok
Old Jun 5, 2009 | 02:26 AM
*18436572*'s Avatar
Car: 83 z28
Engine: vortec5.7/predator/msd/lunati/teamg
Transmission: th350/transbrk/rev-manual v body
Axle/Gears: Ford 9 inch 4:56
lol that's funny ok number I have never seen a knock sensor's threaded boss to ever protrude into a waterjacket????? just put some teflon tape on the sensor's threads and screw it back in, or get another block.I am asumming you have new sensor,try my idea if it dosent work you will have timming issues,I highly doubt it. The knock sensor senses knocking and pinging vibrations in the engine telling the ecu to retard the timming,when your done with repair clear the knock sensor code (if you had one) take it on a test drive and see what happens
Old Jun 5, 2009 | 01:25 PM
eldy's Avatar
Car: 89 formula TPI
Engine: 5.0 l
Transmission: 5 spd
Axle/Gears: 3:45
Happy conclusion.. Thanks to all who replied. You guys were all correct,altho I skipped the teflon tape idea as this would insulate the case from ground. MADMAX you were spot" on" ,the bottom of the hole was just a layer of CRUD!!! I chased the threads and I now know that, indeed , the knock sensor screws right into the water jacket on this small block..THANKS AGAIN.." I have always relied on the kindness of strangers"
Old Jun 5, 2009 | 10:09 PM
*18436572*'s Avatar
Car: 83 z28
oh yea the case ground on the sensor duh!!!!!!!sorry man, lol to much beer
Old Jun 5, 2009 | 10:55 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yes knock sensors and temp sensors etc dont need sealer on the threads.
most ppl dont realize this and that they need to be in contact with the block iron
these kind of fittings have plumbers pipe type of theads in which are self sealing, unlike bolt threads etc.
good luck!
Old Jun 5, 2009 | 11:05 PM
*18436572*'s Avatar
Car: 83 z28
yea your right I was trying to stop his coolant leak (I gonna blame this on budWISER)
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
willyjoejr
Sep 3, 2015 09:26 AM
