1993 Trans am harmonic balancer install problem
Old Jun 7, 2009 | 12:21 PM
Colt44's Avatar
I have a 1993 trans am with a 5.7 lt1 v8
i had to change to optispark so i pulled off the harmonic balancer and i marked witch way it up but that mark came off and its not keyed. if i put it in the wrong way the car will shake horabley. i looked at the end of that crank and all that is there is a little think that says gm and a notch. does that notch indicate top dead center? and on my balancer there is writing and a arrow. does that arrow face tdc? if it did it would face that notch but i am not sure and i can't find anywhere that i can find it
Old Jun 7, 2009 | 03:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1993 Trans am harmonic balancer install problem
that would make sense, however this is a site for 3rd gens, 82-92.
Maybe ask the question in the ltx/lsx swap board in the engine forum, or try ls1tech or other ltx/lsx sites.
Old Jun 7, 2009 | 03:33 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's neutrally balanced, you can put it on in any orientation.
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
lakeffect2
Aug 23, 2015 08:44 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
cRoe4
Aug 7, 2015 08:46 PM
