question about SBC 400
Old Jun 8, 2009 | 08:28 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
Hey I was told if i was building a 406 to go and buy a aftermarket block cause a stock block would be a bad idea what do you guys think?
Old Jun 9, 2009 | 10:03 PM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
Re: question about SBC 400
400 sbc is a hard engine to keep cool cause theres not much material between the cylinder bores and if its bored to a 406 then theres that much less. Id go with a 383 stroker.
Old Jun 10, 2009 | 11:27 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Nothing wrong with it if done correctly. Cooling issues are a non-issue if adequate parts are used.
As for the block itself, depends a lot on the intentions. If it's just a street cruiser, then sure a stock block would probably be alright. If it's a race block, then I would go aftermarket.
Old Jun 10, 2009 | 01:01 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Axle/Gears: 4.10
i should of put this in the begin so everyone knew what i was thinking of doing.. Sorry.. I am think of building a 406 for my camaro to have a street car and run down the track once in awhile. Spray it with nitrous (200 shot) every once in a while. I was going to buy a stock block and buy forged crank,connect rods, and pistons and run ARP bolts, than take it to the machine shop to get all the work done and get a short block build. I know what i will have to do to the heads. I just dont want to build it and run into problem after problem. As far as the cooling goes i was go to redo all of it and buy a brand new Be Cool Rad, and build a great cooling system with Summits Help.
Old Jun 10, 2009 | 02:24 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I would be very carefull when you go to buy a 400 block. If you have the option, have some blocks sonic tested for wall thickness.
I would almost go with a forged 383 too. Just because of the larger availability of a good core block. 200 shot on a stock block 406 worries me. Not a ton, but a little bit.
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
