Turns over VERY slow when hot...
Old Jun 13, 2009 | 12:55 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Is this heat soak? From what I can tell heat soak just makes thes tarter not work at all... so what can cause the car to just turn over really slowly other than a bad battery?
If I give it 5 minutes or so, it turns over normally. It's a fresh battery, and I'm getting 13-14v across the battery terminals when running.
It's just weird...
Old Jun 13, 2009 | 02:14 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: Turns over VERY slow when hot...
it is most likely the starter motor..is the bendix throwing out the small gear to the flywheel like it is suppose to
Old Jun 13, 2009 | 02:22 PM
Brandon033's Avatar
I would do a voltage drop test to see if the battery cable are good.
Old Jun 13, 2009 | 02:54 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
My car has done this to me before, yes heat soak can cause the starter not to operate at all.
About a year ago before I rigged my electric fans to work my car would overheat at idle all the time, so I would shut the car off at idle if it started overheating really bad (steaming, gauge all the way past 260). And one time I did that and when the light turned green it wouldn't start, I had to wait like five minutes for it to crank very slowly.
It still does it sometimes now if I have been driving the car for a while and I park and I shut the car off and need to fix the park job and I key it again and it's a little slow but it always starts.
A torque multiplying mini starter will fix this or heat wrap for the starter usually helps.
Also make sure you have the correct output battery for your car. I'm not sure what ours should be but around 570 CCA should be good I think.
Old Jun 13, 2009 | 03:19 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
best thing for heat soak is to get one of those starter wraps from summit racing. Makes a huge difference.
Old Jun 13, 2009 | 09:53 PM
Car: 1992 Camaro RS
So this is most likely heatsoak then?
I DO have longtubes.
Old Jun 13, 2009 | 10:06 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Yes, probably, especially because you have long tubes, get that starter wrap that xlr8tor recommended, that should do the trick.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
nova983
European Region
Nov 2, 2015 12:15 PM
bbsr72
Sep 27, 2015 05:55 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
