no brake lights
Old Jun 15, 2009 | 11:41 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
no brake lights
I have a 1989 TA 305 with no brake lights. I have done some troubleshooting and replaced the blinker switch thinking it may be the problem. It was not the problem. I Have checked my switch at the brake pedal and it seems fine. I need some wiring diagram info if anyone can help. What can I check next. Help I need some brake lights.
Old Jun 26, 2009 | 01:45 PM
MADMAXGTA's Avatar
Car: 89 TTA
Re: no brake lights
I also have a 89 with no brake lights,my third light comes on but none on the bar.How did you check your switch? i see 2 one with a cruz control hose,and one with out.
Old Jun 26, 2009 | 02:15 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: no brake lights
maybe you have a bad wire in the wiring from the brake switch to the back of the car.
did either of you do anything to the car prior to the lights failing?
Old Jun 26, 2009 | 03:22 PM
MADMAXGTA's Avatar
Car: 89 TTA
Re: no brake lights
I had a tire shop slam my deck lid and brake hatch motor..I have every other lights except brakes on the bar.
Is the brake switch with the third light on it for the tail as well?( it has 2 plugs)
and the other has a hose with a plug,is that strictly for cruz control?
Old Jun 27, 2009 | 12:34 AM
TA-Rocks's Avatar
Re: no brake lights
I have identified my problem and resolved it. I found some corrosion on the fuses at the fuse panel with infinitely high resistance on one wire and very high resistance on my stereo power wires. I replaced the fuses and cleaned up the fuse panel with some Tuff stuff spray cleaner. Im sure battery terminal cleaner would have been better. Wiring information for my car did not come from the useless schematic at the back of Haynes manuals. I was able to get a mechanic shop friend to print the diagrams out from snap on files from his computer. Your left switch is the brake light switch at the brake pedal. The switch should change power on 12v and off with the push of the switch. My brake switch was good but I lost power at my fuses Your brake lights also are driven by the switch inside the steering column which includes the 4 way hazards. These are replaced inside the column with the same switch as the blinker and high beams, etc. My car has probably a rare issue since it was sitting not driven for years and collected moistures inside when it wasnt attended to. I found this wiring to be fairly simple actually. Hopefully this helps you some.
Old Aug 18, 2009 | 04:34 PM
MADMAXGTA's Avatar
Car: 89 TTA
Re: no brake lights
Just fixed my brake lights,after checking bulbs,fuses,switches,It ended up being the turn signal switch...
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
