fuel pump with a mind of its own
Old Jun 16, 2009 | 02:09 AM
phatsaks's Avatar
what causes a fuel pump to continue running after key is turned off i've tried the relay not the problem not sure what is
Old Jun 16, 2009 | 02:20 AM
*18436572*'s Avatar
Car: 83 z28
Engine: vortec5.7/predator/msd/lunati/teamg
Transmission: th350/transbrk/rev-manual v body
Axle/Gears: Ford 9 inch 4:56
Re: fuel pump with a mind of its own
what's the year make and eng of you car?
Old Jun 16, 2009 | 02:22 AM
phatsaks's Avatar
1990
Old Jun 16, 2009 | 02:25 AM
phatsaks's Avatar
2.8 mpfi
Old Jun 16, 2009 | 02:27 AM
*18436572*'s Avatar
Car: 83 z28
ok ,I guessing a camaro, is it tbi,or vortec? does it have the stock motor?(yea it make's a differance)
Old Jun 16, 2009 | 02:29 AM
*18436572*'s Avatar
Car: 83 z28
how long does the fuel pump stay on after key is off?
phatsaks's Avatar
body is a 90 engine is stock out of an 89 i/ve changed wires cap rotor button pump sock filter and relay
Old Jun 16, 2009 | 02:30 AM
phatsaks's Avatar
it continues to run until i kill the battery
Old Jun 16, 2009 | 02:45 AM
*18436572*'s Avatar
Car: 83 z28
ok you have one of to things going on either there is continous power to the control side of the relay or there is continous power to the high side of the relay that send's power to the pump,first remove the f pump relay and see if that kills it,if so replace it with a different relay,you might have another relay like it in the box like the headlight or ac (they should have the same part number),you might have damaged wiring from a fire,of mice,ect is the fuel pump the only thing that stays on?
Old Jun 16, 2009 | 02:47 AM
phatsaks's Avatar
yeah i also have no power idles great try driving it tho and it acts like its running out of gas
Old Jun 16, 2009 | 03:00 AM
*18436572*'s Avatar
Car: 83 z28
ok you might have more than one thing going on.the fuel pump running continously may be a ecu (computer)problem,the pump should cycle for 3 seconds after you turn the key on the first time then it will stop running untill you crank the engine you may want to check the fuel pressure by connecting a guage to the fuel test port on the fuel rail if you have one,or have some one crank the engine while you listen inside the fuel tank thru the filler neck to see if you hear running constantly
Old Jun 16, 2009 | 10:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's the Oil Pressure Sending Unit (OPSU). Where it's located on your engine I don't know - but that's the culprit.
Electric fuel pump gets power from the relay ONLY FOR PRIMING the pump. The continuous power for the fuel pump comes through a connection from the battery directly through the OPSU and directly to the fuel pump. A bad OPSU can cause the pump to run no matter what until the battery is disconnected or dead (Gee - wonder how I know this? LOL).
This is a safety feature built in - no oil pressure = no fuel getting pumped out. But since there is a direct connection between battery and fuel pump through the OPSU - the OPSU can go bad in a way in which it "thinks" it's getting oil pressure when it's not - thus supplying power constantly to the pump. Find and replace the OPSU.
Old Jun 16, 2009 | 10:52 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
got one if you need one...Oil Pressure Sending Unit..was off of my 2.8...
Old Jun 16, 2009 | 11:59 PM
*18436572*'s Avatar
Car: 83 z28
there ya go,I have seen that style circuit on blazer's before,gm must run that on alot of models,sorry did not have schematic sitting In front of me ,cnewbie is the man
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
gta90
Sep 15, 2015 04:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
