zz4 350, want bigger cam
Old Jun 18, 2009 | 01:17 AM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
I have a GM perf parts zz4 350 crate motor in my 86 Iroc. It has aluminum heads and intake both ported and polished. I'd like to get a little bit more power out of the motor and want to upgrade the cam. Any suggestions?
Thanks!
Old Jun 18, 2009 | 08:08 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: zz4 350, want bigger cam
How much lift can your heads support
Old Jun 18, 2009 | 08:06 PM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
not sure. The cylinder heads are the aluminum heads that come with the zz4 crate motor. I currently have what came with the crate motor...a Hydraulic roller tappet pn# 10185071 .474''/.510'' lift and 208/221 degrees @.050'' The valves are 1.94'' intake and 1.50'' exhaust with a rocker arm ratio 1.5:1 I do not know how much the heads can handle nor know how to figure that out. If anyone else knows, please chime in. Thanks
Old Jun 20, 2009 | 02:13 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, with the springs on those heads you're limited to about .525" lift, max.
Old Jul 27, 2009 | 08:21 PM
Sentrek's Avatar
Car: 2006 Pontiac GTO
Engine: 6.0 (383)
Transmission: A4
I would like to assume that if you can put this motor in your 86 iroc i should be able to put it in my 91 rs originally equipped with the 305 tbi. Does anyone know? I have been reading until my eyes are starting to bulge outta my head....I may have found what i believe to be a decent deal on one.
Old Jul 27, 2009 | 08:55 PM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
you have a GTO... and its beautiful.. good taste sir
Old Jul 27, 2009 | 09:08 PM
Sentrek's Avatar
Engine: 6.0 (383)
Transmission: A4
Not only is it beautiful, its got mods and fast as a mother f&^%#r. Thanks! But that doesnt answer my question...
Old Jul 27, 2009 | 10:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
LT4 Hot cam or CC503 cam, kept both with 1.5 rockers, as I'm not sure how high those heads can go but i know they are capable of more lift than stock L98 aluminums which are same type of head.
You carbed or TPI. If TPI, zz4 cam isnt bad choice. Go no bigger than LT4 hotcam. ZZ9 is good for TPI.
Old Jul 28, 2009 | 12:29 AM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
i'm carbed
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Dec 11, 2016 09:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
