Pre 87 head on newer style block?
Old Jun 18, 2009 | 05:18 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
Can aluminum heads designed for pre 87 block be used on 87-later blocks if the correct intake is used?
Old Jun 18, 2009 | 05:26 PM
Twin_Turbo's Avatar
Re: Pre 87 head on newer style block?
the only difference is the bolt angle on the middle intake bolts. 72 deg. instead of 90. W/ correct intake it's a bolt in deal.
Old Jun 18, 2009 | 05:51 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
So if you had say a set of heads from an 86' 305 you could also use your intake from the same motor and bolt it on to say, an 89' 305?
Old Jun 18, 2009 | 09:07 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yes.
Old Jun 18, 2009 | 10:04 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Interesting.. I have heads that were rebuilt with no actual miles on it (a bit of time running before I realized the bottom end was toast) that I wouldn't mind keeping for a spare set since the heads on my rs are getting close to rebuild time.
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
89mulletbird
Aug 12, 2015 07:08 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
