tall Pro-Form valve covers+88-92 serp set up??
Old Jun 19, 2009 | 09:10 AM
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
Using the serp (or gunna try) set up off the original L03 on the 357 im building and was wondering if anyone has ever used tall (Pro-Form) valve covers with the 88-92 serp set up? I ask because im wondering if the driver side valve cover will clear the alternator (or vise versa)
Rob
Old Jun 19, 2009 | 03:12 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: tall Pro-Form valve covers+88-92 serp set up??
got tall elderbrock v-covers on mine and it clears the alt. but its stupid close to the power lead on it. Anytime I have to pull the cover I have to disconect the battery. Its literaly like a 16th of an in. away from it. Actually the pass. side is more of a problem because of the heater hoses. But I know I could fit a set of proforms or any other tall v-cover on it for that matter with very little to no fabrication.
Old Jun 20, 2009 | 09:57 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
Transmission: 5 Speed
I put a piece of plastic in between that power lead and the valve cover.
Old Jun 20, 2009 | 10:40 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
what kind of plastic did you use - it gets pretty hot under there.
Old Jun 21, 2009 | 08:24 AM
JJ63's Avatar
Car: 92 Trans Am
Engine: 350 tpi
It came from the plastic hanger that holds a Sears socket. I just hooked it to the wire and it shields that bolt from the valve cover. It's been on there for the past few years. I do have about 1/2" of clearance though.
Oh yeah, I also trimmed that bolt. It's was so long ago, I forgot about that.
Old Jun 21, 2009 | 09:00 PM
Rob 97 Z28's Avatar
Okay sounds good. So far it maybe a bit close but they'll fit...
Old Jun 22, 2009 | 06:26 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
I got the Billet Specialties tall style valve covers for my vehicle. Trimming the bolt was all the modification I had to do.
Old Jun 22, 2009 | 10:09 AM
Rob 97 Z28's Avatar
Okay well thats not too big of a deal, I just don't want the Alt grounding out on the valve covers...that would be ugly
Old Jun 22, 2009 | 12:18 PM
Jaydog143's Avatar
Car: 1989 Iroc-z
Engine: 5.7L 350
I used an old boot off of a coil wire on mine, fits perfectly. Just removed the wire connector and fed the boot over the wire and clamped the wire connector back on the wire, screw wire on alt. and slide boot up....works great, in fact looks dang near factory.
lakeffect2
Aug 23, 2015 08:44 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
