1971 CHEVELLE 307 ENGINE 2BBL VACUUM HOSE ROUTING
Old Jun 19, 2009 | 09:34 AM
gotay5's Avatar
I NEED A DIAGRAM FOR HOSE ROUTING
FOR 1971 CHEVELLE 307 ENGINE 2BBL
THANX: GOTAY5
Old Jun 19, 2009 | 01:17 PM
Jasper8391's Avatar
Car: 71 Chevelle
Engine: 85 305 TPI map
Transmission: 88 700r4
Re: 1971 CHEVELLE 307 ENGINE 2BBL VACUUM HOSE ROUTING
are you looking for vaccuum hoses?
Old Jun 19, 2009 | 10:54 PM
gotay5's Avatar
Yes Vacuum Hoses
thanx: Gotay
Old Jun 19, 2009 | 11:51 PM
Stephen's Avatar
Car: 87 GTA
This site is dedicated to 82-92 Camaros & Firebirds.
Someone here MIGHT know the info your looking for, but good luck. You'd have better looking on a site dedicated to older cars.
Old Jun 20, 2009 | 12:06 AM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
It is a 71 Chevelle! The 1 vac hose runs from the carb to the vac advance diaphram on the dist.
Old Jun 20, 2009 | 12:22 AM
Stephen's Avatar
Car: 87 GTA
"I NEED A DIAGRAM FOR HOSE ROUTING
FOR 1971 CHEVELLE 307 ENGINE 2BBL"
Only ONE hose? Wow.
Or are you psychic & know what 1 single hose he's asking about?
Old Jun 20, 2009 | 12:33 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Transmission modulator, dash dampers, PCV, and brake booster don't count?
Old Jun 20, 2009 | 11:34 PM
Jasper8391's Avatar
Car: 71 Chevelle
i know the way i have it on my 4bbl is a hose from the pvc valve in the valve covers to the carb and brak booster, and a seperate line from the carb to the distributor. Then theres a vaccuum port on the intake manifold that goes to the transmission (if your running a th350), and one to the grommet in the firewall that has 2 hoses coming out of it. The second hose from that grommet goes to the heater core shutoff valve that comes off the intake manifold.
Hope this helps
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
