cant figure out problem 350 Trans Am
Old Jun 22, 2009 | 07:39 PM
daatv's Avatar
Engine: 350 -5.7 l
Transmission: 5 speed
I have a 1988 trans am with 350 tpi when when i first start it it well stall after it warms up it will fluctuate between 600 to 800 rpm and when i turn the ac on it will drop down around 500 rpm i have also replace the block fan switch the fans should turn on at 200 and off at 180 but instead the turn on at 180 and off at 160 i replace throttle body ,new IAC valve, new fuel pump ,,new O2
censer,fuel filter,and check for vacuum leaks .I am at a lost hopefully some body can give me a new direction
camaro71633
Sep 1, 2015 10:24 AM
TheJoeY88
Aug 13, 2015 06:51 PM
gta power
Aug 13, 2015 06:15 AM
milk
Aug 10, 2015 06:26 PM
