head gasket help
head gasket help
hey i have a stock 350 block with flat top pistons and 906 vortec heads i have a set of felpro 7733sh1 0.015 shim head gaskets and was wondering if thay are to thin if so what should i use and if there not should i use a sealer on them or put them on dry also what should my compression ratio be thank you
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: head gasket help
Steel shim heads gaskets are designed for use with good clean metal. Once they are crushed down from tightening the head bolts, they should never leak.
For some added protection, you can spray both sides of the head gaskets with something like copper spray. I use copper spray on my MLS gaskets.
Rough estimate for compression ratio is 10:1
ambainb
Apr 25, 2016 09:21 PM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
