trouble starting car
Old Jun 24, 2009 | 11:47 AM
AngryBird's Avatar
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
I can not start my car! Here is what I did:
I did not touch the block or heads. I replaced the intake,carb dist, plugs and wires. I put the #1 cylinder at tdc on compression stroke and put in dist withe rotor pointing to #1 cylinder. hooked everything back up.
I have fuel going in to the carb and I have spark at the spark plug.
What am I missing? The car will not start. I will crank the engine and the give it some gas. When I give it the gas I get a pop out of the carb.
any help will be greatly appreciated
jesse
Old Jun 25, 2009 | 12:21 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: trouble starting car
Your timing could be off. Could have the dizzy 180 degrees off.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Wade787b
Sep 29, 2015 01:15 PM
hokis
Aug 9, 2015 03:57 PM
