Intermittent cruise control failure
Old Jun 26, 2009 | 11:36 AM
mclarenryder's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 5.0L 305cid TBI
Transmission: 700-R4
hey friends,
need some help here. i got a 92' rs camaro with the 305 tbi engine and auto trans thats having some cruise control issues. recently replaced the vacuum lines between the servo and the intake manifold to fix an intermittent problem of the cruise disengaging randomly. worked fine for awhile, now the same problem is back. has anyone had problems with the servo before or should i be looking somewhere else. any help would be greatly appreciated, thanks....
btw the car as 150k plus miles on it...
Old Jun 26, 2009 | 01:14 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Intermittent cruise control failure
Did you check the vacuum hose to be sure? Allot of hose sold aftermarket is pure junk and doesn't last especially in high heat areas. Is it still soft and flexible? You might want to replace the switch on the brake pedal, they're not too expensive.
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
TrevinE
Sep 14, 2015 03:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
