milky oil.....
Old Jul 1, 2009 | 08:54 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
milky oil.....
went to change the oil today and it was grey and milky....talk about ruining your day...at least the motor wasnt knocking.... time for a rebuild...just to be safe
Old Jul 1, 2009 | 09:07 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: milky oil.....
id first figure out what caused the milky oil. hopefully the block isn't cracked.
Old Jul 1, 2009 | 09:17 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Re: milky oil.....
that could be exactly what it is....it saw the better side of 7 grand a few times...but i also had it over heat bad on me.... i launched it hard one day and when it twisted it cracked the tank on the radiator..and of course i did my best to baby it home stopping to add water when i needed to...being 50 miles away from home and having something like that happen sucks...when it broke the radiator appearently the interanal tranny cooler cracked also and let coolent into my tranny...so thats thrashed to.....all i can say if it is a cracked block...either a dart block will go back into it...or a new 6.0 ls based
Old Jul 1, 2009 | 10:02 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: milky oil.....
i would think that the car wouldn't run at all if the block cracked. Its most likely a head gasket. Is the block bored at all? i was thinking maybe cracked cylinder wall. Those can be sleeved so maybe all isn't lost. But i would swing towards a ls1 motor and tranny.
Old Jul 1, 2009 | 10:07 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Re: milky oil.....
its just got a .030 over bore....mainly for cleanup, if something is cracked...i already for a 6.0 truck engine with 55000 on it for 1100 at the local yard..
Old Jul 1, 2009 | 10:14 PM
christine...'s Avatar
Re: milky oil.....
My oil is not milky..it looks 'healthy'..but as of late it has started a VERY annoying t i c k ing....
Old Jul 6, 2009 | 09:48 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Re: milky oil.....
got the engine out today...right away i found a blown intake gasket..i had been having trouble with distributor gears and could never figure out why...i thought the oil pump was dragging well when i pulled the intake i noticed a bit of rust around the hole for the distributor and then saw the gasket had torn and pushed into the valley on the back passenger side coolant passageso it must have been shooting water right down onto the cam gear...i thought those 1205 felpro gaskets were suposed to be strong..lol. So at least i know its not the heads or block...gotta pull off the main and rod caps see how all that is....if the crank is thrashed seem like a good time to upgrade to a 383...still doing a complete rebuild anyway...better safe than sorry...
Old Jul 8, 2009 | 09:45 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: milky oil.....
the ticking could be a sticking valve
Old Jul 8, 2009 | 09:49 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Re: milky oil.....
go with a cast crank and get it balanced with all of your components (pistons, rods, rings) its well worth the money. If it wasnt knocking then you should be fine with your bearings.
Old Jul 15, 2009 | 10:12 PM
sparky85's Avatar
Car: 85 camaro
Engine: sbc 400 .30 over
Transmission: 700r4 with bm shift kit, 2200 stall
Axle/Gears: 7.625 10 bolt posi
Re: milky oil.....
that same stuff happened to me too, that ticking went away when i did a oil change with some lukas oil treatment
FireDemonSiC
Apr 21, 2010 11:42 AM
Chevyman84
Apr 23, 2007 11:59 PM
jack harrison
Dec 18, 2006 09:33 PM
BigWhiteGTP
Nov 18, 2006 11:30 PM
adreed24
Mar 17, 2005 08:55 PM
