Starting Problems
Old Jul 6, 2009 | 11:26 AM
bernout's Avatar
Car: 87 GTA
Engine: 5.7L
Starting Problems
HI All,
I have an 87 GTA with the 5.7L. The issue first started when I was driving it, I went to turn Left and the car stalled. I shifted into neutral and it fired right back up, then about 10 mins later I was driving alond and it stalled again. Put into neutral and fired up again. Now the car will not start, it will only turn over but not fire up.The only way the car will fire up is if I use the gas peddle, as if the car was carbed. The car will die as soon as I take my foot off the gas peddle. Thanks in advance for all the Help.
Bernout
Old Jul 6, 2009 | 01:32 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Re: Starting Problems
Check your fuel pressure first.
If that's good then I'd check the MAF sensor - but the problem could still be something else.
What is your location?
Old Jul 6, 2009 | 01:45 PM
bernout's Avatar
Car: 87 GTA
Engine: 5.7L
Thanks, I will be checking the fuel pressure, as for the MAF I hope it's still good as it was replaced about 2000km ago. I'm located in South West Ont, KW area
Old Jul 6, 2009 | 01:48 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Throwing any codes?
Old Jul 6, 2009 | 02:04 PM
bernout's Avatar
Car: 87 GTA
Engine: 5.7L
NOt throwing any codes either, just checked the fuel pressure and it's at 24 psi(If I did it right that is). could this be my problem?
Old Jul 7, 2009 | 09:24 AM
Pukka's Avatar
I do believe that f/p reading is quite low for a TPI setup.
I assume you connected the pressue guage and then turned the ignition to run(no start) before reading the guage?
Either check a Hanyes book or search this forum to find out what the acceptable TPI f/p range is. If it is low, then its probably time to replace the fuel pump/filter.
Old Jul 7, 2009 | 02:40 PM
bernout's Avatar
Car: 87 GTA
Engine: 5.7L
OK Thanks, my chilton says it(fuel pump)should be at 40-47 psi. Now I get to have the fun of dropping the tank. I think it's going to be a PITA, oh well as far as I know it's still the original one.
Old Jul 7, 2009 | 03:03 PM
Pukka's Avatar
Replace the fuel filter first - you might get lucky, but you will eventually have to replace the pump anyway.
Most people swap both at the same time. GL
Old Jul 7, 2009 | 03:12 PM
bernout's Avatar
Car: 87 GTA
Engine: 5.7L
Was going to try that first as I don't know if it has ever been changed at all. Start with the simple thing first.
Thanks Again,
Bernout
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
