Driving with EGR error code (32) bad for car?
Old Jul 9, 2009 | 07:56 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I have a check engine light for EGR. I decided today to remove the plenum so I could remove the EGR valve and clean it. I could not get the EGR valve off since the bolts are impossible to remove with a socket. I tried a small box wrench but the two bolts holding the EGR valve to the manifold are on pretty tight. Looks like you have to fully remove the runners, fuel rails and fuel pressure regulator to get at the EGR bolts.
My car runs fine and pulls hard. Will driving around with error code 32 do damage to my car? I am planning on upgrading to a FIRST intake along with other engine upgrades. Would it be ok to wait until I swap intakes? I don't feel like removing all of the parts now just to clean my EGR valve. Thanks.
Old Jul 10, 2009 | 10:33 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Driving with EGR error code (32) bad for car?
Simple answer no, you will not destroy your motor running with a bad EGR valve. However thats not to say its ok to ignore it till its conveniant eather.
Old Jul 10, 2009 | 11:40 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
*Nevermind, my reply didn't really address your question.*
Last edited by BlueIroc-Z; Jul 11, 2009 at 12:05 AM. Reason: Not directly relative to question.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
squiggy2
Aug 9, 2015 09:30 PM
mustangman65_79
Aug 8, 2015 12:07 PM
