HOW MUCH POWER
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
HOW MUCH POWER
How much hp/torque you say im making?..and what would you say im running through the quarter 1982 camaro z28 it has a mildly built 350 vortec heads, mild cam, high performance high rise holly intake, high performance holly 600 cfm carb, 8. mm spark plug wires, b&m mega shifter,3.23's limited slip rear end, headers, A/C & smog Delete, New 350 Turbo trans, and 10 1/2 MEATS on the back.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: HOW MUCH POWER
-- Joe
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: HOW MUCH POWER
no cam specs, no guess. And your carb is too small. For that combo, order yourself a COMP DualEnergy265 if you like mild cams, a DualEnergy 275 if you want to step up, or an Xtreme4x4 270 or a NitrousXtreme 268 if you want the outer edge of daily driveability. Assuming you're not running roller lifters.
