Head bolts
Old Jul 14, 2009 | 09:09 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Head bolts
Well being this is my first engine build I made the mistake of not putting sealant on the headbolts now what i was do the headbolts under the valve covers go into the water jacket and would it be ok to leave without sealant i already know all the ones along the bottom near the exhaust manifolds go into the water jacket just not sure on the ones under the covers
Old Jul 14, 2009 | 09:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Head bolts
IIRC they all go into the water jacket. Remove one bolt, put sealant on it, and torque it back down. Then go to the next bolt and do the same. After each bolt is R&R'd mark the bolt head with a sharpie or paint dap so that you don't miss any.
Be sure to drain the coolant before doing this.
RBob.
Old Jul 14, 2009 | 09:58 PM
Car: 1988 camaro
Engine: cammed 3.1
Re: Head bolts
RBob.
Do i need to remove the rockers to loosen the ones under the covers?
Old Jul 15, 2009 | 09:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Head bolts
You'll know once you pull the valve covers and try to remove the head bolts.
RBob.
Old Jul 15, 2009 | 03:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't know how many SBC's I put together before I found out the head bolt threads were supposed to have sealant. Never had a problem because of it.
If you aren't getting water into the valve cover area, most likely it never will.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
86White_T/A305
Aug 17, 2015 12:16 AM
