new cam question, what parts should i get?
Old Jul 25, 2009 | 11:17 AM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
ok i was reading my usual super chevy mag. and i came across this add for comp cams thumpr cams. looked it up online and want to order it. but i want to get all parts needed to do the swap. here is the link to the specs on the cam
http://www.compcams.com/Cam_Specs/Ca...?csid=107&sb=2
what im asking is what rocker arms, push rod and springs should i use. im getting the kit with lifters so i wont need to order them.. car is mainly street drivin but will see a strip when i get a chance. part numbers or links would help the most thanks for any help
Old Jul 25, 2009 | 01:49 PM
Engine: ls1 soon
Re: new cam question, what parts should i get?
bump
Old Jul 25, 2009 | 11:58 PM
Engine: ls1 soon
bump
Old Jul 26, 2009 | 12:02 AM
Engine: ls1 soon
nevermind i found it myself thanks for the help
Old Jul 26, 2009 | 12:36 AM
lktna's Avatar
I don't like the Thumper cams. I have heard to many people having problems out of them and the cams not holding up. They are a good sounding cam but lack in preformance. Only way that I would even think about running one is if it was the roller kit which comes with everything you need. So if you are going to put it in a none roller block you would be looking at about $1000 to do it.
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
