Dead Camaro
Old Jul 25, 2009 | 11:26 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Dead Camaro
I was cruising home the other day when for no apparent reason the motor sputtered,backfired a few times and then died. I pulled to the side and tried a re-start. It would fire up for just a split second and then die. It was a hot day so I figured that the ole' L69 vapor lock problem bit me. I waited for about 45 minutes and it started right up. I got about a mile before it died again and fired off three major backfires (probably from me turning the ignition while in motion) and died. I had to have it towed home. When we arrived, if fired right up. I drove it for a couple of blocks, turned it off and on without any problem.
I figured it was for sure the vapor lock issue as I don't have the electric low pressure fuel pump or the carburator heat shield. I went out the next day and now it won't start at all. Now I'm not getting any spark. Checked all wiring. It looks good. I replaced the electronic spark control module with negative results. Any idea what the culprit could be?
justin57
Aug 20, 2015 07:05 PM
Irocohio
Aug 12, 2015 08:03 AM
Bradsaundry
Aug 12, 2015 12:34 AM
hokis
Aug 9, 2015 03:57 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
