Vacuum hose replacement
Car: '91 Firebird
Engine: V6
Where can I find replacement vacuum hose? The only thing they seem to sell at autozone or the other local stores is the silicone tubing. Will this work as well as the original plastic hose?
The previous owner replaced most of the hose with black rubber tubing and im hoping this might be the problem causing my poor idle / problems with the fpr.
Car: 1989 Iroc-z
Engine: 5.7L 350
Axle/Gears: Stock 2.77 posi
Re: Vacuum hose replacement
As long as its getting the air it needs and its not leeking.......why worry. Its really hard to come accross any of the OE plastic vac lines. Better luck at a salvage yard my friend, parts stores aint gona have em.
Car: '91 Firebird
Engine: V6
Ive put my thumb over all the lines, they all have some vacuum. I guess my main question now is that I know the hoses on there are slightly larger diameter than than the originals. Will this prevent the right amount of pressure from being delivered to the fpr?
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
if you are talking about the small head plastic lines they have them at parts stores, but i hate that crap, i replaced all of mine with rubber lines
Car: 1989 Iroc-z
Engine: 5.7L 350
Bigger hose wont hurt man.......Apparently they do sell at auto stores......last time I checked, it was discontinued......
advance auto parts has it, its not behind the counter, its normaly near oil drain plugs and all and with the vacuum "T's" and what not
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Contact these guys: http://www.vpartsinc.com/contact_us.php
They buy NOS items from dealers. They might have them.
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
I would go with the flexible vac lines anyways. I think that those brittle lines are set up with adaptors anyways so there's no real reason why I wouldn't swap out for the 'new hotness' haha.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I bought all new vacuum line at one parts store and ended up with multiple small leaks which gave me a headache trying to get my new set up run/idle and such. Checked a few other stores and found something that worked. It probably depends on where the different stores get their line from, but bring in a fitting and make sure they fit securely. Don't let anyone tell you that it's "good enough" when it isn't.
Car: 89' RS
Engine: 350 TBI
The hoses all have their own specific sizes. When I swapped out all my vac lines, there were zero leaks. That's just me though.
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Larger diameter tubing will have a "lag" effect. The bigger area will take longer to draw the area down. I don't see how this would affect anything but you asked.
Engine: V6, V8
Lol, I wish it were that easy. Both of the hoses I bought were labeled the same size. I thought that they fit too loose so I brought a piece back to the store and was told that they're fine "that's the way they come, they're all manufactured from the same place and there's no difference between them". I went to a couple of other places and compared the hoses and also the fitting and found out that it's not actually the case.
Engine: 5.7 TPI
I get those counter guys sometimes. And to think they get offended when i ask to talk to someone else when i know better then they do.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 16, 2015 05:45 PM
