Leaking oil everywhere... possible rear main seal..
Old Aug 7, 2009 | 07:12 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I know it's a nightmare, but I'm just wondering, how many have changed their rear main seals while the engine is still in the car... Because of this, I may wait until winter and just pull the engine ( It needs some major head work). Was this a common problem on the third gens?
Old Aug 8, 2009 | 09:36 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: Leaking oil everywhere... possible rear main seal..
all 2 piece rear main seals occansionally had this problem. i've fixed them before in the car. but if your engine needs more help than that then i would wait and pull it.
Old Aug 9, 2009 | 02:20 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
It should be known that the 86 or 87+ ( can't remember right now) block uses the 1 piece RMS. I have just replaced mine in the last 2 months ( 88 firebird 5.0TBI ). After dropping the tranny you should have no problems with changing the seal. As far as how long you should wait to replace it, I would say to do it asap. You wouldn't want any oil to drip on the exhaust, possibly causing a under car fire would you?
Old Aug 9, 2009 | 10:07 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Did you pull the torque converter cover and make sure it's the RMS that's leaking? It's much more common for the intake, valve colver, or oil pan to leak and run down.
Old Aug 9, 2009 | 10:32 AM
olskool's Avatar
JV9999 is right. I just got done pulling the tranny out of my '91 about 15 minutes ago only to realize that the oil pan gasket was leaking. I'M PISSED right now.
Make sure you know where it's leaking from before you pull the transmission.
Old Aug 9, 2009 | 01:29 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Or the Oil Pressure Sensor....
Old Aug 9, 2009 | 02:33 PM
jv9999's Avatar
Engine: 5.7L/350
Yea, that too. The oil cooler adapter as well (if it has one).
Old Aug 9, 2009 | 03:47 PM
1989gta's Avatar
Car: 1989 Gta
Engine: 383
i agree with jv9999 rms is that last thing i would check, valve covers have always been the pain in my a$$ do a little cleaning then go for a drive check for new leak. It will save you the trouble of having to put your tranny back in when thats not the issue.
Old Sep 12, 2009 | 12:09 PM
pvalnes's Avatar
Car: 92 dodge minivan
Engine: 350 chev
Transmission: 350 turbo
Hi,
I'm just looking in here and i have a similar situation, i would like to ask some advice about the RMS (i am thinking this old it is a two piece seal) on a 350 Chev that's still in the vehicle. This is a 1978 and it is a van. i have done some nightmarish repairs in my past and i guess i'll do another, do i need to disconnect the motor mounts and the tranny mounts, lift the motor up and pull the pan?
Paul
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
