Fixing a valve cover oil leak and need advice
Old Aug 8, 2009 | 12:54 AM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
I am currently on vacation but when I get back home I plan on putting in new valve cover gaskets. Since I have to remove the valve covers anyway, is there anything I should perform maintenance on in there or something I can upgrade easily? I dont want to have to take off the valve covers again in the near future so if there is anything else I can do in there while the covers are off, I would like to know. Thanks.
Old Aug 8, 2009 | 07:24 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Fixing a valve cover oil leak and need advice
anytime you remove valve covers , just a general look over & clean . then make sure drain holes at lwr. front & rear of each cylinder head are not sludged up . they can cause oil to drain back to crankcase slowly . good luck .
Old Aug 8, 2009 | 09:11 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
If the valve guide seals are 10-15 years old it wouldn't be a bad idea replacing them while the valve covers are off.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
drathaar907
Aug 6, 2015 04:20 PM
