lol,,,clutch fan question,blow toward or away from motor?
Old Aug 10, 2009 | 05:56 PM
my86camaro207's Avatar
having problems with over heating and I just noticed the clutch fan is blowing the air towards the radiator and not sucking in torward the motor..is this right???I thought it should be sucking the air towards the motor
Old Aug 10, 2009 | 06:09 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: lol,,,clutch fan question,blow toward or away from motor?
your are correct, it should be pulling air from outside and blowing on the motor, you might have it on backwards if possible......start car and see which way it's spinning.....you will get some residual air blowing back out front but most should be going over motor
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
