Firebird or Camaro, which is faster ?
Old Aug 15, 2009 | 12:53 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Just wondering if both had identical engine, drivetrain, suspension which would come out ahead. In theory I'd say the Firebird because of the more aero front, but what do you guys think. Later.
Old Aug 15, 2009 | 12:59 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Firebird or Camaro, which is faster ?
Some cars were built better then others... And different options = Different weight. It is a toss up.
Old Aug 15, 2009 | 01:13 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I would note that Lingenfelter chose a TransAm for his land speed record.
Old Aug 15, 2009 | 01:15 PM
Stephen's Avatar
Car: 87 GTA
With everything equal, as far as power, traction, weight, etc.? The Firebird would have a slight advantage, due to aerodynamics. But the driver is the biggest factor in everything.
When I was running autocross regularly, I knew a driver that could beat just about anyone in THEIR car, that they were used to, his 1st time in. He could take a F-stock car & run with E-Street Prepared cars easily.
Old Aug 15, 2009 | 02:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although the Firebird has a better drag coefficient, I doubt you would see any difference in performance unless the vehicles were designed to do 150+ mph. 2 identical street cars but with different body styles would likely be equally fast.
Old Aug 15, 2009 | 02:35 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Also, they had different air intakes, so that also may have some play in this. But then again, at the stock power level, it isn't going to really be noticed.
Old Aug 15, 2009 | 02:54 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i think the firebird... its appears to be more aero than the camaro... there is a german tuner, that has one going over 250mph
Old Aug 15, 2009 | 10:24 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
this one. this car is sick: http://www.autoblog.com/2008/12/22/e...pontiac-trans/
Old Aug 15, 2009 | 10:39 PM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
CAMARO!!! Thats an easy question!
Old Aug 15, 2009 | 10:51 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
... Its all about the Firebirds... They really seem to FLY!
Old Aug 15, 2009 | 11:32 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Camaros got better air intakes
Old Aug 16, 2009 | 03:50 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Firebirds even look faster.
Old Aug 16, 2009 | 04:17 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Originally Posted by battmann
thats the one... makes me tear up a little
Old Aug 17, 2009 | 01:04 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
good to read about the american-bashers getting the correction they deserve. euro snobs are such dumba$$es. If you're serious about going fast, there are only 2 options: (1) a turbocharged big block chevy, or (2) a turbocharged LSX.
Old Aug 17, 2009 | 01:34 PM
John81's Avatar
Car: 1991 Trans Am
Typically I would lean towards a Camaro being 'faster' with equal drivetrains. My thinking on this is Firebirds were generally the higher end model and weighed a little more, not counting Formula's.
Old Aug 17, 2009 | 01:49 PM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
lets not stick our heads up our ***** on this either... amg( Mercedes tuner) has been producing some of the fastest street legal vehicles around.
Old Aug 17, 2009 | 02:15 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
street legal? that depends on the laws of the various countries. For ultimate HP potential, no Mercedes engine can approach the capabilities of the LSX block, and there are BBCs out there over 3000 HP. The HP required increases at the cube of the speed increase. So, to go faster, you need more HP. And unless you want to go from piston engines to jets or rockets, the HP champs of this planet are the 2 I named. If they want to rival us, they'll have to use one of our engines, or build a one-off.
Old Aug 18, 2009 | 12:24 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
i meant emmissions and actually drivable
Old Aug 18, 2009 | 12:48 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
well besides the euro cars mentioned above???????
I would say camaros, because you can get a police package (yes mine is) in those....and police radios are faster than any car.....LOL.
okay sorry, I know that was cheesy....
still go camaro!! lol
Old Aug 18, 2009 | 01:14 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Wasnt the turbo trans am the fastest third gen of all the factory third gens? Beond that there were actual magazine tests on this very thing cant remeber which magazine or what particular year but the way it ended up breaking down the IROC camaro had better low end speed because of its better intake giving it alittle hp boost over the firebird but the Trans Ams better aerodynamics allowed it to overtake the camaro in the top end. Oddly enough though they ended up with the same top speed which was something in the low 140s. That being said I thing a Firebird formula 350 would be the best of them all. They could have all the T/A performance options whith about 300 lbs less than the T/A which would push it beyond not only the T/As but the IROCs and Z28s as well by a narrow margin. The only ones that i cannot account for are 1LEs, SLP cars, or any special package car of that nature.
Old Aug 18, 2009 | 01:17 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
lol that u are correct
Old Aug 18, 2009 | 10:28 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Does it really matter?
Old Aug 18, 2009 | 12:10 PM
Engine: L98 494hp
But of course......
I agree though on the special cars......the firehawk was offered to the pontiac guys, which did outperform them all.....camaro was not offered that special intake system...although I don't know much about them....only ever seen one..
Old Aug 18, 2009 | 01:23 PM
F-Body Demon's Avatar
Turbo Trans Am.
Booya!
Old Aug 18, 2009 | 01:30 PM
Engine: L98 494hp
what were the specs on that....wasn't it just a turbo 4 cyl.... or like the old TA 301 turbo cars???
Old Aug 18, 2009 | 10:21 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
If your referring to the Turbo TA it was the infamous buick 3.8
Old Aug 18, 2009 | 10:25 PM
Stephen's Avatar
Car: 87 GTA
The 301 he's referring to, was a 2nd gen turbo car. (i thought it was a 304?)
The Buick 3.8 was in the 89 TTA.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Grant2k
Jul 10, 2018 04:01 PM
Linson
Aug 21, 2015 02:12 PM
TheExaminer
Aug 19, 2015 10:07 PM
