Seafoam?
Old Aug 16, 2009 | 03:40 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Seafoam?
Hey guys I just bought a bottle of the stuff and I just want a few opinions on it before I dump it into my T/A. (after I get her to start on her own again). Any tips/warnings would be great too.
Old Aug 16, 2009 | 03:47 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Seafoam?
yea got get another 2 cans
pour one in the gas tank
take and put a vac line in another can and let it suck up into the engine till it dies, let it sit for a while remove the vac line from the can and start it up (may take a few trys) ......start over, do it over again
last can right before your next oil change pour a can in the oil and ride around the block 2 times or so and then change the oil normaly
Old Aug 16, 2009 | 03:49 PM
Engine: LB9
Re: Seafoam?
Oh lovely... more money to put into this money pit. LOL
You'll need to help me with the vacuum line, which one is that? How do I identify it?
Old Aug 16, 2009 | 03:57 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
Re: Seafoam?
its well worth it. i do induction services with it all the time. and use it on my bird too
Old Aug 16, 2009 | 04:59 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Re: Seafoam?
Money well spent
When you start it up for the first time it will smoke....alot. This is normal, and quite fun. The more it smokes the more you needed to do it.
All my cars get this treatment every couple of years.
Old Aug 16, 2009 | 05:28 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Seafoam?
I'll be the dissenting opinion. It's just oil, alcohol, and naphtha. Gas is already 10% alcohol in most parts. The oil makes a nice smokescreen. You can always pour a little lighter fluid in there (naphtha) if it makes you feel better. I think the effect is more phychological than measurable.
Old Aug 16, 2009 | 05:44 PM
89RS_82Z's Avatar
Re: Seafoam?
it will clean your intake real well, they also make a spary sea foam to clean the area before your vac line
or you can just use regular carb cleaner there (throttle blades)
a good vac line to use is the brake booster or the line going to the PCV (un hook it from the PCV and stick it in the sea foam can)
someone with TPI needs to chime in on the best vac line for TPI, im used to carbs and TBI on older V8's
Old Aug 16, 2009 | 08:20 PM
Car: 90 formula
Transmission: auto
Re: Seafoam?
Originally Posted by Krik
Money well spent
quite fun going full throttle at a red light after needing the foam badly.
Old Aug 17, 2009 | 04:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Seafoam?
On TPI I use one of the lines going to the charcoal canister. Better chance of it hitting all of the runners instead of just putting it in the back of the plenum.
It didn't clean my engine very well. 20 miles before a teardown I seafoamed the car. I was trying to not have to tear down.
To me it looked as if the seafoam did nothing to my intake tract.
gta892000
Aug 11, 2019 11:16 AM
86White_T/A305
Mar 6, 2016 01:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rjcme
Sep 5, 2015 01:23 PM
bakerstreet
May 29, 2007 09:56 PM
