87 iroc wont stay running
Old Aug 22, 2009 | 11:16 AM
94turboss's Avatar
hi i have a 87 iroc i just bought but when you fire it up it will idle for a sec and then just load up and flood out the guy i bought it from said he just had new heads and a small cam put in it and its done this every since he got it back together. didnt know if anyone else has had this trouble? also he said he has put almost all new sensors on it and none helped . thanks brantley
Old Aug 22, 2009 | 12:57 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: 87 iroc wont stay running
Is this a TPI (tuned port) engine or does it now have a carb on it? I'd guess the cam change really screwed up the injection system. You might have to get some serious ECM tuning done to get it to run right, assuming the previous work was even done correctly. Could be many other things too. Pretty much impossible to diagnose over the net. I'd start with checking fuel pressure and try to get the ignition timing somewhere close to right.
Old Aug 23, 2009 | 08:53 PM
94turboss's Avatar
ya i dont know what cam or anything is in it. i still havent even went and picked up the car i bought it and its still at the other guys house. but he said after the cam change he picked it up drove about 40 miles and then it did what its doing now when u fire it up it wil run then it will flood out and die and fill up the cylinders with fuel and you have to remove the spark plugs to drain it i was wondering if there is any way the injectors could be sticking ?
Old Aug 23, 2009 | 10:09 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
the cylinders fill up with FUEL?? as in fill...?
seems you would have a number of problems first of which is injectors locked open really couldnt see the fuel rails having enough in them to fill a cylinder not to mention more than one
also need to change/check the oil cylinders dont really seal when the engine isnt running so that fuel is leaking into the oil and can destroy an engine
does it only leak into 1 specific cylinder or is it random or all of them? would seem like valves might not be sealing properly... granted not the biggest problem at the moment...
that fuel problem isnt caused by a cam or tune though the unknow cam may complicate the situation...
for that much fuel to be accumulating he will have had to have rigged the fuel pump to run off of a switch or something as once the engine had stopped running the pump would shut off and the lines would bleed out into the engine with the injectors stuck open maybe a less than a pint of fuel total across several cylinders...
if you havent already signed the bill of sale dont.... as this sounds like the deepend of fubar
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Sherpajames
Aug 7, 2015 06:56 PM
