Tail lights work but break lights dont
Old Aug 23, 2009 | 12:03 AM
thelastz28's Avatar
I took my car to get an alignment and rear break service done... Now my break lights don't work. What happened? Thanks for the help.
Old Aug 23, 2009 | 12:23 AM
Stephen's Avatar
Car: 87 GTA
Re: Tail lights work but break lights dont
Break job & an alignment, have nothing to do with the functionality of the brake lights.
Could just be a coincidence. Have you checked your fuses? Checked the bulbs themselves?
Old Aug 23, 2009 | 12:29 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
check by your brake pedal switch. the switch that doesnt have a vacuum hose to it, press it manually. i had a room mate that paid a shop to fix it. all they did was charge 50 bucks and used a ziptie that eventually left the lights on, all the time. of coarse i fixed it. i just used another ziptie. haha it was a blazer, he was broke.
Old Aug 23, 2009 | 12:44 AM
thelastz28's Avatar
Where is the break pedal switch located? I'll check the fuse also, thanks.
Old Aug 23, 2009 | 12:51 AM
Stephen's Avatar
Car: 87 GTA
The arm that holds the pedal, is what pushes on the switch, so look behind the arm, under the dash.
Old Aug 23, 2009 | 01:01 AM
thelastz28's Avatar
Thanks Stephen.
Old Aug 23, 2009 | 07:25 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The dangling white thing is the brake switch. I presume it's likely the same for yours. It will be in a bracket in front of the brake pedal. When apply the brake in it will release the switch. Pretty simple. Just make sure the switch is working properly.
Old Aug 23, 2009 | 10:35 PM
thelastz28's Avatar
I replaced the fuse and it worked the first time, but then the fuse blew. It did it with 2 other fuses too. What could be causing this? Thanks for the help, guys.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
