idle. problems
Old Aug 22, 2009 | 05:03 PM
2c2g's Avatar
Car: 88 trans am
Engine: 305 tpi
idle. problems
i have an 88 t/a with 305 tpi and it wont idle or keep running once it starts,I have replaced the iac vavle and installed to spec but wont run unless i unplug the maf sensor, it runs when i do that but it idles at about 1100 rpm and of course run rough at highway speeds.Is it a bad maf sensor ?Will a ODB 1 help me diagnose this problem?As soon as i plug the maf back in it wont idle.And how do check the Maf to make sure it's bad?
Any help with this woiuld greatly appreciated
2C2G (Chris)
Old Aug 22, 2009 | 05:07 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: idle. problems
connect the maf, start engine, slap the maf. if it surges then bam its the maf. test for codes jump the top two terminals (a and B) by your knees called the diagnostic link.with th key to on, (not start) it should shoot you sum codes
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
greenyone
Sep 2, 2015 03:39 PM
