Broken Oil Filter Mount...?
Old Aug 22, 2009 | 07:56 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Never dealt with anything like this, so i dont know what to do.
Trying to start up my car after an engine swap, and i cant get any oil pressure.
Checked underneath to see what was going on, and the oil filter was leaking like a screen door. I thought maybe i left the old gasket in there, but nope.....
I noticed that the part the oil filter SCREWS ON TO, is very loose. I can jiggle it around....
Is my motor f-d? or can i replace/repair this....?
I have no idea how its held there or anything, any help appreciated.
Old Aug 22, 2009 | 08:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Broken Oil Filter Mount...?
the adapter is bolted to the engine.
Old Aug 22, 2009 | 08:28 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
there shouldbe 2 screws/ bolts that bolt the screw on piece to the block proabably loose if your worried u can get the screw on piece from GM and the 2 screws/bolts no biggie unless the bolts are stripped or broken good luck
Old Aug 24, 2009 | 10:33 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Took it out today, its split in two. Whats the part called?
Gonna order a replacement.
Old Aug 25, 2009 | 04:11 AM
tom86iroc's Avatar
Car: 1986 iroc
GM dealer not sure of the # just tell them its where the filterr mounts to the block and get the 2 bolts for it too better safe then sorry
Old Aug 25, 2009 | 07:44 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
It's called an oil filter adapter.
Old Aug 25, 2009 | 12:57 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yes. You can probably get one at a parts store.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
skeltor
Feb 2, 2016 10:37 AM
carattini
Sep 10, 2015 07:46 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
